Re: H noise front of trans
Posted by rustyfarmall on December 20, 2009 at 13:13:38 from (209.152.78.140):
In Reply to: H noise front of trans posted by charles todd on December 19, 2009 at 16:20:43:
The drive shaft for the belly pump is seperate from the main drive, or clutch shaft. You still need to drop the belly pump to gain access to everything else. The noise is most likely the transmission main input shaft bearing.
