Re: farmall m,wheel locked
Posted by Owen Aaland on December 20, 2009 at 15:17:06 from (65.161.86.2):
In Reply to: farmall m,wheel locked posted by jim from az on December 19, 2009 at 16:21:47:
Start by draining the oil and removing the PTO. That should allow you access to see what is causing the axle to be locked. If the problem is the brake locking the pinion gear you would a little bit of movement with the tire.
