Re: Cub with two snow blades attached(pics)
Posted by Daniel Robertson on December 20, 2009 at 15:54:33 from (67.162.93.46):
In Reply to: Re: Cub with two snow blades attached(pics) posted by tractorsam on December 20, 2009 at 15:35:41:
third party image
The oil going thru the filter is oil returning from the remote cyls. to the reservoir. The valve spool is equipped with a power beyond port with high pressure oil continuing to the TC lift. This puts the 4 spool remote valve as primary, and the TC cyl. as secondary. If you study this schematic a little bit I think it will make some sense.
Dan Robertson
