Re: farmall 560 diesel starter
Posted by gregg7817 on December 20, 2009 at 17:15:25 from (173.22.213.27):
In Reply to: farmall 560 diesel starter posted by clayg100 on December 20, 2009 at 17:06:14:
Is the tractor setting outside? If so you may need a block heater or radiator heater to keep the block warm. You should also use a lighter weight oil so it won"t be so thick. Make sure you push the clutch in too.
