Re: 6 volt/12 volt? - NOT "How do I convert to 12 v&
Posted by Jim Becker on December 20, 2009 at 19:27:29 from (173.57.141.22):
In Reply to: 6 volt/12 volt? - NOT "How do I convert to 12 v" posted by sflem849 on December 18, 2009 at 15:15:38:
Most regulators are (or were when new) labeled to indicate voltage. They were also labeled for polarity, if it mattered. The marking may be stamped in or printed on. It is usually on one of the mounting brackets or somewhere on the bottom side. Most Delcos have it stamped into one of the mounting brackets. There will be some combination or 6 or 12, maybe a V and maybe a P or N. Maybe be POS or NEG. Might say "P 6V" or simply "12N".
There is a troubleshooting procedure on a web page. I don't have the pointer handy, but somebody usually posts it on any charging problem thread. I would expect a 6-volt regulator to test as "bad" if mounted on a 12-volt system.
One quick test is to directly ground the generator "F" terminal. Check voltage at the "A" terminal. This bypasses all the regulating function of the regulator and should put the generator at full output. Check voltage at the "A" terminal. If this voltage is above what you measure at the battery, the regulator is bad.
I am assuming you have good grounds everywhere, including the generator shell and the regulator.
