Re: What all did MW make?
Posted by billde on December 20, 2009 at 20:07:26 from (72.26.89.156):
In Reply to: What all did MW make? posted by Andrew Z on December 18, 2009 at 18:50:04:
sflem849 said: (quoted from post at 21:58:06 12/19/09)
Ry said: (quoted from post at 06:23:07 12/19/09) M and W made a different radiator grille for the M farmall that had smaller holes and also was raised up on the front - to keep hay etc. out of the radiator....
Think it was called a "Super Snoot"
I thought the super snoot was used in corn picker operations to get fresh air in bc the nose was blocked by the mounted picker. I may be wrong.
The screen in the grille would get plugged with trash and cause overheating. the Super Snoot screen was above the grille, it would still plug once in a while but was a lot easier to clean off.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
