Re: farmall 560 diesel starter
Posted by Brownie 450 on December 21, 2009 at 03:55:03 from (66.43.241.141):
In Reply to: farmall 560 diesel starter posted by clayg100 on December 20, 2009 at 17:06:14:
Check all connections including where the ground goes to the frame/ or in this case--the steering casting. When cranking, feel all connection spots & where the 2 terminals are on the solenoid. If any feel hot, you have a bad terminal end. Same for the back of the solenoid--heat there might be evidence of the contact disc or terminal studs going South. Batteries should be checked first for charge.--Assuming you already have done this.
