Posted by PaulW_NJ on December 21, 2009 at 04:50:05 from (74.105.12.241):
Charles
I sent you an email the other day, but don't know if you received it.
I am in the conceptual phase of how to modify the hydraulics I’ve got, on my 340U. My objective is to add a loader, and also to add remotes at the rear.
I am not familiar with how the hydraulics on a 504 like yours are set up, and if they are totally different than a 340 perhaps this won’t apply. What caught my attention is that it looks like on your 504 you have a similar camshaft driven external pump as mine, as well as a second internal pump.
My 340U has an existing 9 gpm pump on the camshaft, similar to yours, but no internal pump. I’ve read that a 11 (or 12) gpm pump, or the 17 gpm pumps were IH options, and one or the other would have been mounted internally, instead of the external 9 gpm pump. My 340 has two pairs of side remotes with valves, and control levers, that I planned to use for the loader. I also wanted to split the output of the remote to be used for bucket control with a three way valve, and send the alternative output to a third pair of remotes on the rear, where I can connect a log splitter.
My existing 9 gpm pump therefore provides hydraulics to the rear fasthitch, the power steering, and the two existing side remotes. My concern is that 9 gpm will end up being too low a flowrate for running the loader, or the rear connected log splitter. Of course I won’t be running both at the same time. It has been suggested to me that an easier approach would be to wait and see how the 9 gpm pumps works, and then if it is too slow to add a PTO powered Prince-type pump, at least for the log splitter. That, however sounds equally complicated if I have to also add a tank and additional controls. My gut feeling is that the 9 gpm will be insufficient.
On the 340, the camshaft driven pump draws fluid out of the transmission, and dumps it back there after the pressure is let down. I assume the internal pump option would have worked in the same way. Because I don’t know how the internals would have been configured at the factory if the internal pump option were in place, I have no way to know what internal components besides the pump itself I might need to add the internal pump, or if it is even feasible to retrofit one at this point. Another thing I’ve wondered is whether I could add the 12 gpm internal pump, keep the 9 gpm camshaft pump in place, and run both together.
Any thoughts would be helpful, and greatly appreciated.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
