Posted by Janicholson on December 21, 2009 at 06:51:06 from (64.61.211.143):
In Reply to: compression readings posted by Indiana George on December 20, 2009 at 14:08:36:
I would ad that the readings could be low for three reasons (but they are not very low) 1 The throttle could have been closed causing some vacuum on the intake side when doing the check, must be wide open. 2 The rotation speed of the starter could be low causing low test pressure (must crank fast) 3 The accuracy of all gauges need to be checked once in a while! It is not the issue with starting though. Weak spark, or fuel mix, or vacuum leak, or fouled plugs will do that! JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
