Re: super m hydraulics
Posted by glennster on December 21, 2009 at 09:15:55 from (76.217.101.141):
In Reply to: super m hydraulics posted by jdetig1 on December 21, 2009 at 08:25:37:
yup, a splitter valve will work as long as it is an open center valve. as far as plumbing to the belly pump, i prefer to run the line to the drain plug, use a pipe tee, the plug the third opening with a pipe plug. (easier to drain the fluid that way.) you can plumb to the fill pipe, but it will need a vent hole and sometimes it will squirt hydraulic fluid out the vent. (generally only when you are standing next to it!!!)
