Re: Super A Problems...not starting
Posted by El Toro on December 21, 2009 at 09:17:13 from (74.103.74.58):
In Reply to: Super A Problems...not starting posted by Brian Luton on December 21, 2009 at 08:17:24:
You probably need to pull No1 sparkplug near the radiator and bring that piston to TDC on the compression stroke. Once you have the No1 piston at TDC pull the distributor cap and see where your rotor is pointing. It should be pointing to the No1 plug tower in the one/two o'clock area. As in this firing order. Hal
2-1
4-3 As the rotor rotates CW.
PS: If you're sure you're at TDC on the compression stroke with No1 piston and the rotor
is pointing somewhere else, your engine probably has jumped time. Could be the timing gear or the drive gear on the distributor.
