sflem849 said: (quoted from post at 07:54:06 12/21/09)
mkirsch said: (quoted from post at 07:15:19 12/21/09) All 560s are 12V.
Gas tractors have one 12V battery.
Diesel tractors should have two 6V batteries, hooked + to - with a short battery cable, to make 12V. Once connected, it works exactly the same as a single 12V battery. Treat it like a single 12V battery.
For charging and jumping, you hook the red clamp to the + on the first battery, and hook the black clamp to the - on the second battery. You do NOT connect anything to the short cable at all.
Use the *12V* boost setting.
That is what I figured. They were doing this way back on the MD's.
With that said I could confuse the subject. :roll: You can take two 12 volt batteries and hook them + to + and - to - for twice the cranking amps. IDK what the battery boxes look like on the 460/560, but you can do it on the big Deeres pretty easy ie4440. It wouldn't really work on something like a 4020 with the long skinny 6 volt boxes.
Actuall sflem you have the correct solution. I ran JD A's for many years with the original 2/6v hooked in series to make 12v and always had slow starts. Then for LESS MONEY I bought 2 small 12v and hooked them in parrallel and had 12v with twice the cranking amps and much easier starting.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
