Re: What type of wire?
Posted by Brownie 450 on December 22, 2009 at 03:32:52 from (66.43.241.141):
In Reply to: What type of wire? posted by KenB_Texas on December 21, 2009 at 22:15:12:
SO is sunlight & oil resistant jacket. If you have a 10SI, you really only need 1 length of #9 wire to go from the alt. "hot" terminal back to the ammeter.
Sounds like you have a bad voltage regulator [internal] &/or a shorted diode in the rectifier. Prove this out by disconnecting the wires at the alt. overnight. You would be better off with stranded wire for hook-ups.
