Re: Farmall c loader question
Posted by mkirsch on December 22, 2009 at 05:27:38 from (64.80.108.55):
In Reply to: Farmall c loader question posted by Beatles65 on December 21, 2009 at 17:34:10:
You need to take the valve apart, clean it up, and replace the o-rings and gaskets. It's leaking.
You may also need to do the same thing with the C's Touch Control (the hydraulic block under the gas tank).
That loader will fit the C, Super C, 200, 230, and possibly the Farmall 240. It's a relatively rare, but not valuable, loader. You don't see many around because the frameless C design does not make a good loader tractor. The engine block simply isn't strong enough to hold up to much abuse. If the owner uses the tractor as a bulldozer, it will break.
