Re: What type of wire?
Posted by old on December 22, 2009 at 08:03:03 from (4.245.4.59):
In Reply to: What type of wire? posted by KenB_Texas on December 21, 2009 at 22:15:12:
You need #10 fro the one wire off the big post of the alternator and all others can be #12 or #14 I prefer #12 because it is heavier then the #14 so holds up better over time.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
