Posted by Andrew Z on December 22, 2009 at 08:13:41 from (64.252.44.45):
In Reply to: MD Crankcase Dilution posted by sflem849 on December 22, 2009 at 06:44:16:
really sounds like the injectors are at fault here. does the engine smoke really bad, or exssive blow by ? one thing that imconfused on is you say your getting diesel in the engine crankcase or in the bottom of the injector pump ? id imagine that it would be pretty hard to have diesel pour into the crankcase. unless... the injector pump is filling up with fuel and the front pump seal is bad cause fuel to leak into the crankcase that way. if this is the case then the seals in the pump are bad, leaking fuel into the oil for the pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
