Posted by sflem849 on December 22, 2009 at 13:04:28 from (66.254.196.101):
In Reply to: MD Crankcase Dilution posted by J Wilbur on December 22, 2009 at 06:44:16:
Andrew Z said: (quoted from post at 13:15:48 12/22/09) Ok, thats good to know that the pump is not leaking fuel directly into the crank. I would suspect what you thought then with the injectors. When i had my injectors rebuilt two of them were near pluged solid and the 3 of them were opening at way to low of a pressure. Thus just "dumping" fuel into the cylinders, not a fine mist like it should be. When i had them done it cost around 275 to have all 4 done. You unfortunatly can not test them on your own beacuse there are speical tools required to test pressure, flow and so forth. The only question i have to lift pump is how much pressure you are getting out of it? This would be the gauge on the side of the pump. The gague just shows a red and white range, remove that gauge and install a regular pressure gauge with number 0-100lbs will work fine. you should have at least 40 lbs of pressure.
Andrew
A gauge with white and red on it!?! Mine is yellow with a bunch of oil :D I will get a regular gauge and throw it in there to quantify the pressure.
Where did you send your injectors?
EDIT - Any idea on the fuel bowl leaking down? Just a poor gasket fit? Nothing leaks when it is running and the bowl fills up to capacity.
This post was edited by sflem849 at 13:24:35 12/22/09.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
