Re: 240 valve spring
Posted by Cliff S on December 22, 2009 at 16:12:26 from (64.136.26.231):
In Reply to: 240 valve spring posted by Red Rocket on December 22, 2009 at 13:09:13:
Stock 340 springs are 80# if I remember right!
I Run my Pullers with 340 heads up to 3000 RPMs without any Problem!
What are you Puttin it in ?
A Puller I Hope?
