Re: REALLY weird engine problem!
Posted by mkirsch on December 23, 2009 at 05:22:09 from (64.80.108.55):
In Reply to: REALLY weird engine problem! posted by Howard H. on December 22, 2009 at 19:50:18:
The C60 (Cub/LoBoy) engine is a FLAT HEAD, valve-in-block style engine.
I just looked at a C60 head and to verify, and you definitely cannot see the pistons through the spark plug holes.
Don't pull the pan yet!
Place your thumb over each spark plug hole and crank. I bet you'll get a whoosh of air. That means the pistons are going up and down, and the valves are opening and closing.
Check for spark like your Dad taught you on the old push mower. Take the plug out, put it back on the wire, and lay it against the block.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
