Your problem is, the tractor needs hydraulic pressure to operate the TA. Without that there is no way power will get from the engine to the rear wheels.
If anything is a weak point on these tractors, that's it. Takes 30 years to get there, but when it does, you're dead in the water...
Unfortunately, the pressure plate is probably damaged from the splines letting go, so you will have to replace it. Since you have to replace the pressure plate, you really should replace the clutch too, and for best results with the new clutch, you should have the flywheel resurfaced.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
