Posted by Theman on December 23, 2009 at 05:52:13 from (63.107.135.35):
In Reply to: 46 H oil leaks posted by Illinois Farmall on December 22, 2009 at 20:04:41:
It is OK to remove the inspection plate between the Liftall and the transmission. If a seal is leaking pretty good and the liftall drive coupling has slung oil everywhere, you might not isolate the source until you wipe everything down then watch for it. There are 3 seals in that area that can be your problem. The Liftall pump/reservoir should be removed from the housing to replace any of them anyway. They all can be replaced without splitting the tractor at the transmission. Once you have found the source of the leak, do an archive search to find suggestions on replacing that particular seal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
