Re: 46 H oil leaks
Posted by Andy Martin on December 23, 2009 at 06:36:04 from (199.197.2.143):
In Reply to: Re: 46 H oil leaks posted by Illinois Farmall on December 22, 2009 at 22:08:12:
He meant is it coming from the engine, the transmission or the LiftAll. In my definition, as soon as I pour it in the LiftAll it becomes hydraulic fluid.
If it is hydraulic fluid you may have a bad LiftAll seal or you may have another leak on the unit. It will all run out the same place. Check that the three external pressure connections to the LiftAll are tight first.
