Posted by Owen Aaland on December 23, 2009 at 18:25:43 from (65.165.246.148):
In Reply to: 1586 engine posted by out of luck on December 23, 2009 at 18:01:28:
Technically the answer is no, but only because your tractor has a 436 in it and that size engine was never used in trucks.
Trucks used the 466 engine and there have been many of them installed in tractors. It is basically the same engine with a longer stroke on the crankshaft. You will need to change the front and rear covers and manifolds. You should also replace the injection pump or have it reworked so you have the correct governor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
