Re: Farmall B Rear Wheel Rims Question
Posted by ScottyHOMEy on December 24, 2009 at 06:58:48 from (71.241.194.58):
In Reply to: Farmall B Rear Wheel Rims Question posted by Stephen McCoy on December 24, 2009 at 06:30:45:
There were actually everything from 7-11" rims made for the As and Bs.
If you can find a 7" rim (I have no idea how common they are) you could do what you want. But I think you could also do it with 9.4x24 tires on 8" rims. Don't know what you have for a trailer, but the typical car hauler is just about 7' between the fenders. The narrowest treadwidth for a B is 64", and you have to add the width of one tire (half the width of two tires), so with 9.5s you're up to 73-1/2. You'd still have room to move them out 4" on each side enough for your chains to clear, but bungee up the loose ends) and get between 7' fenders if that's the target. That extra 8" of width is gained by dishing the wheels in and mounting the rims with the inside of the lug mounted to the side of the wheel closer to the tractor, so that the wide side of the rim is away from the tractor.
I'm just suggesting 8" rims and 9.5 tires might be a lot easier to come by and still accomplish what you want to do.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
