Re: Farmall B Rear Wheel Rims Question
Posted by Jim Becker on December 24, 2009 at 07:57:13 from (173.57.141.22):
In Reply to: Farmall B Rear Wheel Rims Question posted by Stephen McCoy on December 24, 2009 at 06:30:45:
I doubt you will be able to both fit the tractor on your trailer and have clearance for chains with the tires set at the same width. Not likely to have room for chains with a 64" treadwidth, even with 8.3 tires on 7" rims.
To answer your original question, The bolt circle of the Cub rims is not quite the same as the A/B rims. They do not directly bolt on. The offset of the lugs is different too. If the bolt circle matched, the narrowest treadwidth would be 66".
