Re: Farmall B Rear Wheel Rims Question
Posted by gene bender on December 24, 2009 at 08:57:59 from (67.55.226.179):
In Reply to: Farmall B Rear Wheel Rims Question posted by Stephen McCoy on December 24, 2009 at 06:30:45:
If you have the cast centers they are thicker than the steel ones. Now you can use the 7in rims on the B then use a 8.3x24 tire. If you use the 8 in rime the 9,5 will fit good. The 8.3 will be 72 wide on the 7in rims. You will not have clearence with the 8in rims set in the narrow position as the rim will hit the final drive the rim will have to be mounted outside of the center. Mite want to call me im sw of ia cityand have several Bs with different tires i do have some original rims 319-430-3907
