Re: International 460 Utility
Posted by pete 23 on December 24, 2009 at 13:13:39 from (173.87.0.174):
In Reply to: International 460 Utility posted by Dave Paxton on December 24, 2009 at 08:20:51:
If tractor will move normally with ta lever back,the over running clutch in ta is jammed locking carrier. Only saw this happen once in all my 40 plus years working on IH tractors. Take little four bolt cover off over ta and give carrier a wack in normal direction of rotation and you may ge able to use direct drive until you get a chance to repair the ta. If transmission was in two gears you would not be able to move at all.
