Super C Head
Posted by RDJ Farms on December 24, 2009 at 14:47:52 from (4.167.134.204):
I have two heads, one is a 251172 R1 and the other is a 251172 R2. The only differance I can tell between the two is one has longer valve springs and valve stems. Are the heads the same other than the valves? And can you put the longer or shorter valves in eather head? If I remember right the R2 has the shorter valves in it now.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
