Re: super c crankshaft pulley
Posted by El Toro on December 25, 2009 at 04:40:36 from (74.103.74.58):
In Reply to: Re: super c crankshaft pulley posted by CNKS on December 24, 2009 at 18:24:26:
You leave the bolts loose so when you install the pulley the cover & seal will center itself.
You could probably heat the pulley to 200 degrees and use that 1/2" center hole in the crankshaft to press the pulley on. That pulley is going to cool a lot by the time you get it installed. Probably won't be any hotter than when you've worked the tractor all day in 90 degree heat. Is that pulley hub nice & smooth?
Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
