Posted by gene bender on December 25, 2009 at 10:02:13 from (67.55.226.179):
In Reply to: C113 rebuild questions posted by WellWorn on December 25, 2009 at 09:06:42:
If the block isnt cracked between the cycls you can justgrind the area and you could use JB Weld or fiberglass the crack. I have on that i ground so it was clean. I then used the rubber cement that body shops use on installing windshields. It has been on several three day tractor rides,parades and everyday use and no leaks. If you can get the block warm in that area then when the cement is still soft you can take a brush and rough it and it will look like cast paint and go. The repair was made 5 yrs ago and still works. Depending on sleeve wear a good ring job will last a long time depending ou your use of course. Yes the 6v system will start with the 3 1/8 hi-domes. Just need a good set of cables 1ga and a starter in shape new brushes ect. Mine start with 5-30 oil down below zero.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
