I tried to post a pictorial of the hydro system but it won't work.
Go to the IH parts page and type in 300 then scroll to the U and hydraulics.
The link below may work.
The pump is more than likely the problem. If you have the aluminum pump they usually cannot be rebuilt.
BUT, I had a similar problem with my case 1030 and it was the relief valve sticking and NOT the pump. All I did was take the relief valve out and clean it and put it back in and it works fine.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
