Re: C113 rebuild questions
Posted by El Toro on December 25, 2009 at 11:37:15 from (74.103.74.58):
In Reply to: C113 rebuild questions posted by WellWorn on December 25, 2009 at 09:06:42:
If it was mine I would find another block with block number 354898R1. Use the crankshaft, rods and cam from the old engine. Have the crankshaft measured for wear at your local auto machine shop and have them furnish the new bearings even if it has to ground undersize. Get a new sleeve kit and have the old rods installed on the new pistons. The head probably needs to reworked too. Your tractor's engine will then las a long time. You can also transfer your hydraulic pump. Hal
