Re: C113 rebuild questions
Posted by gene bender on December 25, 2009 at 12:23:40 from (67.55.226.179):
In Reply to: C113 rebuild questions posted by WellWorn on December 25, 2009 at 09:06:42:
You can put a water pump on the engine you now have and dont need to change radiators. Over the yrs junk will settle at the bottom of the sleeves blocking the nickle sezed holes and wont let coolant flow out the lower part of the block thus causing bubbling when its worked hard. If you decide to replace he sleeves you will fing a lot of stuff there. Yhe bottom lin is what are you going to towork the tractor for. Mite just replace the rings and it will run for a long time.
