Posted by tractorsam on December 26, 2009 at 10:14:36 from (142.68.40.121):
In Reply to: Blowby posted by gary sedlacek on December 26, 2009 at 10:06:16:
What are you wondering?
If you don"t use the tractor much it"s probably normal. Usually a milky tinge to the oil would indicate water contamination, which if it doesn"t get good and hot on a semi-regular basis it almost certainly will have. If you just let it run for an hour (rather than used it for an hour) you won"t even have got that engine to operating temperature. As the engine runs a certain amount of the combustion gases will leak past the rings, a portion of these gases is water vapour. If it"s cool outside the water vapour will condense and mix with the oil vapour coming out the blowby tube. This is most likely what you"re seeing. Sam
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
