Re: Farmall C will not crank over
Posted by clint S on December 26, 2009 at 17:27:52 from (24.92.241.43):
In Reply to: Farmall C will not crank over posted by Beatles65 on December 26, 2009 at 17:13:00:
Is the switch pulled out all the way? Do the lights Dim when you pull? Do you have voltage to the saddle?
Could be bad a bad ground, Bad switch, bad wire, bad starter/ starter stuck on ring gear.
Check for voltage first. With the switch on, test for voltage at the saddle if you have it it is the starter or bad ground remove and bench test starter and clean both surfaces reinstall and try again.
If not work your way back to the switch. If you have voltage before the switch and not after, bad switch, if voltage after the switch, bad wire. No voltage before the switch, bad wiring from there.
Sounds like a bad ground though.
