Red mist is correct on the FBK. If you need some useless trivia info the diesel version was FDBK ######
Your hood will probably have an extra small hole in front of the gas tank opening. This 7/8(?) gallon tank was for good gas while distallate was stored in the big tank. You would start on the good gas and then run on the distallate. It had less power, but it was really cheap. Other indicators of a former distallate tractor include a heat regulating manifold. Not sure if that is what it is really called, but it had a lever thing on the side that you could control the manifold heat with. They also came with radiator shutters to make the tractor run hotter. I guess they needed to be good and warm to burn the junk fuel.
Do some research on it and you will find a lot of info.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
