Posted by Jeff Z. on December 27, 2009 at 08:42:56 from (74.76.3.113):
In Reply to: Transmission flush? posted by Zachary Hoyt on December 27, 2009 at 08:12:24:
First open the drain and let all water out. It is not a good idea to put solvents in the transmission. Drive the tractor around and get the fluid as hot as you can. Drain and let set for a few days with the drain plug out. Refill and do it again. Get the fluid hot. Let the second fill drain with the plug drain open for a day or two also. For the cost of two fills it will be worth it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
