Re: Leaking Coil
Posted by Bob on December 27, 2009 at 11:22:15 from (69.178.228.68):
In Reply to: Leaking Coil posted by Tweeter on December 27, 2009 at 11:17:08:
Coils are oil-filled for insulation and also the oil transfers heat from the windings to the outer shell for cooling.
They seldom leak unless physically damaged or overheated.
Is this ignition system as-original 6 Volt or a a 12 Volt conversion?
