Re: Rebuilding My H Steering Bolster
Posted by Rollie NE PA on December 27, 2009 at 12:14:54 from (71.173.56.37):
In Reply to: Rebuilding My H Steering Bolster posted by ktheo1 on December 27, 2009 at 11:06:08:
The way I do it is to remove the grill, remove the sector gear cover then jack the front end up high enough for the bolster shaft to come out the bottom of the bolster housing. After you have the front end jacked up you can remove the front wheel assembly from the bolster shaft. Then remove the sector gear. Be careful, the shaft will drop out the bottom. There are 2 bushings in the housing and a bearing in the bottom of the shaft.
I just drive the bushings out with a long bar. When you put the new lower bushing back in make sure you have the grease hole lined up with the grease fitting in the bolster housing.
One of the bolts that holds the front wheel assembly to the bolster shaft
has a raised head. This prevents the wheels from turning 360 degrees. Be sure to put the bolt back in the proper location.
Hope this helps. Rollie
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
