Re: Super A starter not engaging?
Posted by riverbend on December 28, 2009 at 04:24:07 from (208.160.33.156):
In Reply to: Re: Super A starter not engaging? posted by Cue P. on December 27, 2009 at 20:35:40:
Remove the ground cable from the battery, then the cable from that starter. Be careful not to turn the cable stud on the starter when removing the cable.
Unbolt the starter and that's it. It is self contained and there is no timing associated with the starter.
Greg
