Re: Saginaw 3 Point Hitches
Posted by Bob Kerr on December 28, 2009 at 12:13:53 from (216.249.73.7):
In Reply to: Saginaw 3 Point Hitches posted by 856Red on December 27, 2009 at 18:32:44:
I have one on a 51 H and have nothing but good things to say about it. It mounted right up and I can still use the swinging drawbar. It is very heavy duty and will pick up logs big enough to pick up the tractor front end with no problems. I just use the belly pump and no down pressure which has not be a problem so far.
