you will need to remove the front end and the engine as a whole if you want to remove the crank shaft or the cam. You need to remove the timing cover and front pulley. If you just want to grind the valves and re-ring the engine then no you dont have to. However from the sounds of it you want a full true overhaul main and rod bearings, crank ground, cam bearings and have the cam checked for wear; then yes you will have to remove the entire front end.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
