Re: cub will not start.
Posted by James Rumph on December 28, 2009 at 12:48:12 from (24.192.125.175):
In Reply to: cub will not start. posted by garyandnancy on December 28, 2009 at 09:10:16:
Did you put points in it ? If you did are you sure you used the insulators between the distributor housing and the power wire.
Did you take it apart ? The screws that hold the points plate a certain length and if to long they hit the advance weights and it won't start.
Did you just clean the carb out or did you install a cheap rebuild kit.
If you rebuilt it with one of those Tractor Supply kits that is the hole problem. "JUNK" ..
