Posted by ChadS on December 28, 2009 at 14:11:56 from (4.225.93.233):
In Reply to: Tractor Will Not Start posted by Bemidji 52 M on December 28, 2009 at 14:03:42:
Its possible the cam nut fell off and the cam gear slid enough, or stripped the key way.
Check all the usual places, pins in the distributor shaft, or the drives.
Live HYD pump tractors without a left handed cam nut are famous for this, I hope this isnt another case.
Im not too sure on how to check for that without taking something apart. Might have sheered a key inside the pump??
I would say, pulling the oil pan off and seeing if the cam is moving,,,, if it does and no slop, it has to be a roll pin, or a keyway in the pump? ChadS
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
