Re: Rebuilding My H Steering Bolster
Posted by CVA59 on December 28, 2009 at 14:44:45 from (75.23.33.65):
In Reply to: Rebuilding My H Steering Bolster posted by Ric KS. on December 27, 2009 at 11:06:08:
sflem849 said: (quoted from post at 20:00:43 12/27/09)
CVA59 said: (quoted from post at 19:44:12 12/27/09)
glennster said: (quoted from post at 16:17:28 12/27/09) carter and gruenewald has the complete rebuild kit, upper and lower bushings, bearings seals and the lower steering shaft bearing and seals for about 150 dollars. heres a link
poke here
Wow, I little pricy. I only plan to replace what is bad. Is there anyone who sells the individual pieces?
I am sure Carter and Gruenwald could sell just the neccesary pieces as well. They are a local IH dealer. Not too big compared to a lot of the local dealers, but I wonder if other CNH dealers can get the stuff as well??? Just a thought.
Just an FYI - You can look up parts on the internet. What I do is use my local dealers link www.triebold.com and navigate from there. Not sure if you can get there straight from the CNH website. This site will tell you if the parts are still available. They have some catching up to do compared to Deere. You can't check price, availabilty, order if unavailable, or order for pickup/delivery like you can on the JD website. I am sure it is coming.
Thanks for this info. I called my Case dealer today and he does not show any parts for a 1943 H front end bolster. So, I will keep on trying. I also try Carter and Gruenwald and see what they say. I am hoping it is just a worn out bearing. I can move the bolster around quite a bit.
