Posted by D Slater on December 28, 2009 at 16:43:50 from (72.65.132.6):
In Reply to: Tractor Will Not Start posted by Bemidji 52 M on December 28, 2009 at 14:03:42:
Since you already tried cranking with no start and if it still cranks at good speed. Engage the hydraulics while cranking to see if the pump still pumps. If it does check the rear pump drive lug key, distribtor drive gears and pin. If it doesn't try to pump look at gear and shaft on the front of pump and if okay you can also see the cam gear through pump drive hole. stick your finger or something else in hole to see if gear moves anyway but with a little backlash, or if you roll engine and see teeth missing or a broken gear forget about shaking it. If you find those problems or the gear doesn't move when engine is turned, its front engine cover removale time.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
