Re: Farmall M Carburetor Adjustment
Posted by JMOR on December 28, 2009 at 16:56:12 from (72.181.166.239):
In Reply to: Farmall M Carburetor Adjustment posted by Brian Luton on December 28, 2009 at 16:39:11:
Your adjustment isn't very likely to be the reason that it will not run, because while the main adjust can be closed down to save fuel under light load work, it is recommended in the manual to have it a full five turns out for heavy work........not that is a broad range over which it will run fine.
Idle mixture, you set for fastest idle. This can be so wrong that it won't idle, but will still run at speed.
