Re: Tractor Will Not Start
Posted by El Toro on December 28, 2009 at 17:01:39 from (74.103.74.58):
In Reply to: Tractor Will Not Start posted by Bemidji 52 M on December 28, 2009 at 14:03:42:
third party image
Pull the distributor and see if the drive gear on it is ok. If the gear looks ok and the woodruff key isn't sheared. Look down inside where the distributor was installed and have someone just bump the engine over easily and see if the gear is moving that drives the distributor. You will need a good flashlight. If they not moving I think you're going to have to pull off the front of the engine to get to the timing gear. Hal
