Re: cub will not start.
Posted by El Toro on December 28, 2009 at 17:20:02 from (74.103.74.58):
In Reply to: cub will not start. posted by garyandnancy on December 28, 2009 at 09:10:16:
Pour several teaspoonfuls of gas on top of several pistons then reinstall the plugs and see if it will fire like its going to start. If it does it means you're not getting gas to the engine. You should be able to hold your hand over the throat of the carburetor to make it start. Pull the gas line at the carb and see it there's a full stream of gas from the tank. Catch the gas in a clean container. Make sure your plug wires are in this firing on the cap. Hal
2-1
4-3 Rotor turns CW.
