Re: Super H won't start
Posted by Dellbertt on December 29, 2009 at 05:53:47 from (209.172.22.95):
In Reply to: Super H won't start posted by Derrel on December 29, 2009 at 05:28:21:
With fuel running out of carb the first thing to check is float sticking down.
Tap LIGHTLY on the side of the carb then turn off fuel at sediment bowl, drain carb and see if it will start. If it starts turn on fuel and let it run awhile.
You may also have other problems but this is a start.
Dell
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
